    Applying "fish scales" to an irregular surface
    15 Posts 5 Posters 1.2k Views 5 Watching
      driven
      did in my quick test...
      • cottyC
        cotty
        Nice, which steps are you using for this result?
        my SketchUp gallery
          driven
          I just applied the bottom row manually, selected the row, then Move copy 12x...
          I then tilted [Rotated] the component geometry 2º on 2 axis to overlap each other...
          johnyou have to drag them from the Component Browser...
          • W
            wheelz
            Nice!
            I think that will do it.
            Now to add another layer of complexity... can you think of a way to have all of the circles rotate in 2 axis relative to the plane that they are attaching to?
            • KrisidiousK
              Krisidious
              Japanese Roof Tile Fish End Cap.skp
              By: Kristoff Rand
                driven
                that's basically what happens when you adjust the internal geometry...add guide for easier selecting...
                you could start with a more obvious input point and erase it at the end...
                • W
                  wheelz
                  I get that, but it falls apart when the irregular surface starts curving in both directions, as is the case with the project that I'm working on.
                  example
                    driven
                    copy paste your wall into a new skp and color the target faces a distinct color and I'll see if some ruby code can add them in place...
                    • pbacotP
                      Wonder if flowify would help. In reality it would distort the scales, but that may not be noticeable.
                      • cottyC
                        cotty
                        Worth a try...
                        flowify_fish.zip
                        my SketchUp gallery
                        • W
                          wheelz
                          really appreciate the help.
                          file is attached
                          recordWall
