Mystery Lines
I've been trying to figure out what these lines are. In the picture, you'll see gray lines that outline the walls behind the current walls. I'm fairly new to SketchUp and have never encountered this issue before. Any help would be greatly appreciated.
You've turned on "Back edges" in the view menu, probably with the shortcut "k"...
Thank You,
Aaron Arechiga -
Moved from the Bugs forum because this isn't a bug.
Register LoginAdvertisement
