    Nested object
    3 Posts 2 Posters 538 Views 2 Watching
    • A
      AijAij
      In my model I found an empty nested object. When using the orbit to rotate the model, certain items are showing as nested object to re-appear normal after releasing the orbit.
      There is also 1 unidentified nested object outside of my working space. I can not select anything in theis area, so I can also not select the nested item.
      The nest appeared after I have cut out an imported component. The box of the component was way bigger then the itmen holding it, so I just cut the itme loose from the component and paste it back outside of its own component. Left me with this mysterious nest whithout any contents.
      I can not select it or whatsoever. Showing hidden geometry does not show anything.
      Anybody has an idea how to get rid of this junkbox? πŸ˜•
      • U
        unearthed
        If you can, put the model on here. Save it as version 8 to increase eyes on the problem.
        Growplan - People ∩ Plants ∩ Place
        windows 7 64b, 4GB RAM, SU 8.0.16846
        Gimp, QGIS, Vectorworks 12, Bricscad 11
        • A
          AijAij
          I have deleted the imported object from my model and the nest has disappeared aswell.
          Must have been something to do with that. Anyway thanks for your interrest Unearthed.
