    Deleting Component Instance
    5 Posts 4 Posters 1.0k Views 4 Watching
    • bomastudioB
      bomastudio
      Hi guys. I'm inserting into my model two Component
      pants_path1 = Sketchup.find_support_file("myCOMPO1.skp" ,"Plugins")
      pants_def1 = Skecthup.active_model.definitions.load(pants_path1)
      pG1 = Geom;;Ponit3d.new(0,0,5)
      transform1 = Geom;;Transformation.new(pG1)
      compo1 = @entities.add_instance(pants_def1, transform1)
      compo1.name="Name1"
      compo1.locked = true
      and similarly for the 2nd Component
      pants_path2 = Sketchup.find_support_file("myCOMPO2.skp" ,"Plugins")
      pants_def2 = Skecthup.active_model.definitions.load(pants_path2)
      pG2 = Geom;;Ponit3d.new(0,0,10)
      transform2 = Geom;;Transformation.new(pG2)
      compo2 = @entities.add_instance(pants_def2, transform2)
      compo2.name="Name2"
      compo2.locked = true
      If, in a separate function, I try to delete those Components through an iteration I get a Error: #<TypeError: reference to deleted Entity>.
      def eraseCompo()
      Sketchup.active_model.active_entities.each{|e|
       if e.typename=="ComponentInstance"
        if e.name=="Name1" or e.name=="Name2"
         Sketchup.active_model.erase_entities(e)
      What I'm missing?
      • TIGT
        Try this...
        Sketchup.active_model.active_entities.grep(Sketchup;;ComponentInstance).select{|e|
          e.name=="Name1" || e.name=="Name2"
        }.each{|e| e.erase! if e.valid? }
        • sdmitchS
          sdmitch
          > compo1.name="Name1"
          > compo2.name="Name2"
          def eraseCompo()
          >   end
          >  end
          What I'm missing?
          The mis-spelling of Sketchup in the .load statements, and Point3d in the Geom::Transformation statements?
          Sketchup.active_model.erase_entities(e) should be e.erase!
          http://sdmitch.blogspot.com/
          • Dan RathbunD
            Dan Rathbun
            Your missing the number one rule of iterating collections (in any programming language.)
            Do not delete collection members while iterating the collection. The loop will lose it's place, and strange results occur. In that case, always iterate an array copy of the collection, if your loop must remove or add collection members. This is most often seen while modifying Entities collections.
            In TIG's example, he used the select method, which produces a separate new array subset of the original collection.
            The simplest way to get an array copy, is using the to_a method.
            The second good thing TIG showed was to always check your API Entity sub-class objects for validity.
            I'm not here much anymore.
            • bomastudioB
              bomastudio
              Guys you are and invaluable support for SU developers.... a beer to all of you!!!
