    Join Pipes Smoothly?
    27 Posts 10 Posters 2.4k Views 10 Watching
    • KrisidiousK Offline
      Krisidious
      Fredo Lines2Tubes
      I guess it will do... I wish it were welded though.
      Took longer here wrting and answering... But, I'd still rather have a pipe plugin that saw this geometry and knew I wanted 3" pipe in that general shape and welded.
      Or am I back to the new Profile Builder?
      By: Kristoff Rand
      • sdmitchS Offline
        sdmitch
        rollbar5.jpg is why I put a sphere at each vertex. That eliminates the outside gaps.
        http://sdmitch.blogspot.com/
          Why not use Plugins specialized in Pipes ?
          Like 3SKeng or this free one by Architectboy?
            Krisidious
            a roll bar is one solid piece and the less pieces the better on the system.
            http://s3images.coroflot.com/user_files/individual_files/original_221352_5TgHTnNTM6oQ_yH1OYPItE4Ok.jpg
            By: Kristoff Rand
            • andybotA Offline
              andybot
              @krisidious said:
              Andybot, that did work, but each vert had to be welding 1 at a time. again pretty time consuming.
              I selected all the vertices and used "merge close vertices" with a distance of 0.3 Much quicker than if you do it individually. πŸ˜„
              It deletes some faces in the back though, but generate faces fixed that pretty easily. Also need to remove inner faces (There's a plugin for that πŸ˜„ )
                With what plugins ?
                • andybotA Offline
                  andybot
                  @pilou - Vertex Tools
                  • 2 / 2
