    Referencing a loose face from inside a component?
    5 Posts 3 Posters 513 Views 3 Watching
    • U Offline
      unearthed
      Is there a way for a face in a component to reference a loose face elsewhere in the file? This would be so I can have an assemblage of loose faces which remain topologically editable (connected faces change shape), and then referencing from that to a component which I could query and also show as an individual land parcel
      I've also asked this here - http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=62574%26amp;p=573589#p573589
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
        slbaumgartner
        I don't think you can make a separate component automatically track a loose geometry face, but if you select the face you can easily move a copy aside to use as your parcel.
        • U Offline
          unearthed
          Does this discussion http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=48742%26amp;p=437723#p437723 between hgroeneveld and Tig a few years ago help understanding this area?
          especially this part...
          "Attributes usually persist in new copies/clones/duplicates.
          It's a bad idea to attach attributes to things like faces and edges because these do get overwritten/replaced when geometry explodes or is intersected, or even edits are 'undone'."
          BUT while you say tracking a loose face from a component may not be possible, would it be possible to traverse an aarea of loose faces and build a component from that?, with the area of loose faces being used a live reference
          I'm not a programmer, I'm just trying to define what's possible in SU as a lot of seemingly impossible things get solved here.
          • sdmitchS Offline
            sdmitch
            It is possible, using attributes, to 'pair' a face in a component with a loose face and 'update' the component face when the loose face is changed.
            http://sdmitch.blogspot.com/
            • U Offline
              unearthed
              That is an amazing plugin sdmitch - is Face Pairs a plugin you would be willing to make available (or sell)?
