    SketchUp to ArchiCad?
    16 Posts 4 Posters 6.7k Views 4 Watching
    • J
      japettler
      We're having a lot of trouble, as in 0 success, importing a simple SketchUp model into ArchiCad. Googling forums and help from ArchiCAD seems to make it fairly easy, yet by using the tips we've found we simply can't get this to work. Does anyone have any sure fire tips or tricks or perhaps something we've completely overlooked that will allow us to import a model created in 2015 Pro into ArchiCAD 17? ArchiCAD says they have fully integrated support with this release.
      Thank you for your help.
      • K
        KrisM
        Try saving the SU model to an earlier version, perhaps version 8. Archicad doesn't necessarily like the current version of SU.
        KrisM
        • J
          japettler
          Thanks Kris,
          We read that saving down to version 5 would work, but it didn't. Not sure if by chance another earlier version would work. Have others had success doing this?
          • JQLJ
            JQL
            Have you tried IFC export from Sketchup and import into ArchiCAD?
            That's what I'd immediately try though I never did...
            www.casca.pt
            Visit us on facebook!
            • J
              japettler
              We tried IFC export and import as well. ArchiCAD gave us an error message when trying to open the file.
              I should also clarify that when opening the skp file in ArchiCAD it does create an object but it's just a dot and contains no real information.
              • JQLJ
                JQL
                I'm not a good person to help you as I never tried anything like that, but I'm very curious to know what you will eventually achieve.
                Why don't you post this in Sketchup forums. There you will have direct contact with Trimble team and there you can clearly see they are very concerned with all things BIM related. This will certainly be a matter of interest to them.
                www.casca.pt
                • JQLJ
                  JQL
                  Here's the link:
                  Site Not Found - Discourse
                  (forums.sketchup.com)
                  www.casca.pt
                  • J
                    japettler
                    Thanks! It's possible I'll reach a different audience there so I'll put a similar post on their boards. I think the issue is more on the ArchiCAD side though. We've called their tech support and they put us in a queue so who knows when we'll hear back.
                    • JQLJ
                      JQL
                      @japettler said:
                      It's possible I'll reach a different audience there...
                      I'm sure you will!
                      www.casca.pt
                      • HornOxxH
                        HornOxx
                        Hi japettle
                        in the context of this thread, I would like to ask an additional question
                        Today I have received a SkUp file, exported from ArchiCad.
                        All the geometry and all the layers are transferred perfectly.
                        My problem now is, that no instance, group or component is obtained.
                        Everything is now a "slurry" of surfaces and lines.
                        Is there is no way to export ArchiCad to SKP, and still keeping the groups or instances?
                        Since you are using ArchiCAD, I would appreciate any hint...
                        Regards
                        never trust a skinny cook
                        • J
                          japettler
                          Sorry I'm not going to be much help with the conversation from ArchiCAD to SketchUp. My experience is limited. We're transitioning from 2d AutoCAD and SU to ArchiCAD BIM and SU for supplemental stuff. Our hope was actually to use SU as a schematic design tool to help build models in ArchiCAD. Our first go-round so far has been unsuccessful.
                          Good luck to you and if you find a solution please reply here for others looking for a solution to similar problem.
                          • JQLJ
                            JQL
                            @hornoxx said:
                            Hi japettle
                            Regards
                            An obvious but tedious solution to your problem would be to export multiple isolated components of your model into Archicad.
                            You can find plugins to export all components to a folder.
                            The problem will be inserting them in the correct place inside your model.
                            www.casca.pt
                            • HornOxxH
                              HornOxx
                              thank you all for your informations and tips.
                              There are many dialogues on web about this topic. Many ArchiCad users recommend to use
                              the "old" DWG Export for keeping groups and instances. Assuming I will get a DWG export file
                              from the architect, I will try that and report here, whether this works with more success...
                              • K
                                KrisM
                                In Revit, I use a dwg export with the options set to export as autocad solids. This creates a perfect export / import to Skecthup with everything grouped appropriately. Does such an option exist in Archicad? Only downside is that the materials don't come across.
                                • HornOxxH
                                  HornOxx
                                  ArchiCAD to SketchUp - Just for your information.
                                  Meanwhile, I have received a DWG export from ArchiCAD.
                                  The first conspicuous behavior is that the exported SKP file sice was about 100 MB, the exported DWG file sice of the same model content was only about 10 MB. For this sice not even DropBox was necessary, that could be sent by email.
                                  The model groups or model components have been preserved, which made it at least possible to work with this file.
                                  Unfortunately, almost all surfaces are triangulated, which would mean a huge amount of cleaning.
                                  (This triangulation effect did not occur in the previous SKP Export)
                                  Although there are only a few types of windows, which are recognized by SkUp as a component, it brought no advantage, since all (same) components are numbered now - such as Window 01, Window 02, etc.
                                  Overall - I could work with this file, but I could use it in first place just as a template.
                                  • J
                                    japettler
                                    Sorry I can't be more help with the ArchiCAD to SU transfer but I do have a solution to my original post. It turns out you have to save down to SketchUp 7. We figured this out a couple weeks ago but thought I'd share and put a bookend on this one. Thanks for everyone's input.
