    Size of select point on Mac OSX 10.10
    4 Posts 4 Posters 343 Views 4 Watching
      raphdag
      Hello,
      I've upgraded from Mavericks to Yosemite. Since that, the size of select point became ridiculous : I almost can't see it! Before that, on OSX 10.9, it was big and comfortable...
      Anyone has met the issue?
      Raphaël
      • tuna1957T Offline
        tuna1957
        Have seen posts in the past that this is an issue with mac's retina screen. Not sure if it relates to yosemite os. Have the same problem with new macbook pro w/ yosemite and retina screen. Kind of non issue for me as I run a bigger moniter when I'm working in SU.
          slbaumgartner
          There are known issues with markers being too small to see on high-dpi displays such as mac retina, but I have never before heard it associated with an upgrade from Mavericks to Yosemite. Are you sure you didn't modify your display settings along the way? Check what is set on System Preferences->Display.
            driven
            you may have previously reset your cursor size in System Preferences [I do]...
            and it may not have survived the upgrade...
            If not you can do that now, just a thought...
            john
