    Location of Sketchup 2015 Folders/Files
    2 Posts 2 Posters 436 Views 2 Watching
    • S
      sectionaa
      Attempting to find where I should place the updated Fredo Lib plugin, I was unsure where it should go. I then catalogued all the file locations for Fredo Tools (Other plugins are similar I expect).
      Is this insane?
      FILE LOCATIONS - SKETCHUP 2015 - FREDO
      C:\Users\me\Application Data\Temp
      C:\Users\me\Application Data\Application Data\Temp
      C:\Users\me\Application Data\Application Data\LIBFREDO6_DATA_Dir
      C:\Users\me\Application Data\Sketchup\Sketchup 2015\Sketchup\Plugins\Fredo6_FredoTools
      C:\Users\me\AppData\Roaming\Temp
      C:\Users\me\AppData\Roaming\Sketchup\Sketchup 2015\Sketchup\Plugins\Fredo6_FredoTools\IMAGES_Standard
      C:\Users\me\AppData\Roaming\Sketchup\Sketchup 2015\Sketchup\Plugins\Fredo6_FredoScale
      C:\Users\me\AppData\Roaming\Sketchup\Sketchup 2015\Sketchup\Plugins\Fredo6_!LibFredo6
      C:\Users\me\AppData\Roaming\Application Data\Temp
      C:\Users\me\AppData\Roaming\Application Data\LIBFREDO6_data_Dir
      C:\Users\me\AppData\AppData\Local\Temp
      C:\Users\me\AppData\AppData\Local\LIBFREDO6_DATA_Dir
      C:\Documents and Settings\me\Application Data\Sketchup\Sketchup 2015\Sketchup\Plugins\Fredo6_FredoTools
      C:\Documents and Settings\me\Application Data\Application Data\Temp
      C:\Documents and Settings\me\AppData\Roaming\Temp
      C:\Documents and Settings\me\AppData\Roaming\Sketchup\Sketchup 2015\Sketchup\Plugins\Fredo6_FredoTools
      C:\Documents and Settings\me\AppData\Roaming\Sketchup\Sketchup 2015\Sketchup\Plugins\Fredo6_FredoScale
      C:\Documents and Settings\me\AppData\Roaming\Sketchup\Sketchup 2015\Sketchup\Plugins\Fredo6_!LibFredo6
      C:\Documents and Settings\me\AppData\Roaming\Application Data\Temp
      C:\Documents and Settings\me\AppData\Local\Temp\
        You should be installing it using the SCF Plugin Store tool so the files get put in their proper locations. Or, at the very least, download the RBZ file and use Install Extension.
        I think you should be able to clear the Temp folder entries.
