    VRAY RT render engine issue
    renderpluginsextensions
    5 Posts 2 Posters 811 Views 2 Watching
      robertobanderas
      this is what comes outHello,
      Im having trouble making my RT rendering work properly, for some reason even though regular renders come out properly with materials and lighting correctly, when I try to use the RT engine to work on tuneing up the scene it comes out like the picture attached. The checkbox of the override material is off and thats why regular renders do work fine, is only the RT im having issues with.
      Any help would be very appreciated, thanks πŸ˜„
      • andybotA Offline
        andybot
        change your RT mode to "RT CPU" GPU is not currently fully supported
          robertobanderas
          Hey andy, thanks for the help. It made it a little different but its still "grayed out" with the switch to CPU mode. Any other suggestion?
          It came out like the image below.
          • andybotA Offline
            andybot
            Not sure why. In this case probably the best thing to do is load default options and start from scratch. Change only the options you need (env., camera, output, etc.) and don't mess with RT settings. It should work right out of the box.
              robertobanderas
              That seeemed to do the trick ! thanks a lot for the help !
