    Animation do not work
    2 Posts 2 Posters 220 Views 2 Watching
      lolo17
      Hello
      i am using sketchup make,
      i create some scènes but nothing happens when i click on the différents scene
      it show always the last scene .
      do you have an idea on what i miss to do?
      • ntxdaveN Offline
        ntxdave
        @lolo17 said:
        Hello
        I can think of a couple of possibilities:
        1. When you created your new scene, did you click on the Update scene button? When you added the new scene and moved the camera, if you do not click the Update Scene button, it will revert back to the original scene settings when you navigate from scene to scene
        2. What are you clicking to navigate the scenes? If you click on the scene tab, it should animate from one scene to the next (again assuming you clicked the Update Scene button when you created the scene). If you click on the scene name in the Scene dropdown list, you will continue to see the last scene because you are really not going to that scene you are only navigating through the scene list.
        Hope this helps you.
        Press F1...thank me later
