    Any GOOD dxf writing guides? (Autodesk seems dead)
    4 Posts 2 Posters 855 Views 2 Watching
    • dereiD Offline
      derei
      I need a GOOD dxf guideline to include as much as I can take from a SU file (layers, line types, colors-based on materials), etc.
      Also I want to be able to produce the file compatible with CNC (i don't know if there is some specific requirement or file architecture)
      I tried to find something...either I find general info only, or really old.
      Autodesk seem to have only dead links: http://www.autodesk.com/techpubs/autocad/acad2000/dxf/writing_a_dxf_file_dxf_aa.htm (other dxf-related links are equally dead)
      Thanks for any help.
      DESIGNER AND ARTIST DEREI.UK
      • dereiD Offline
        derei
        Umm, nothing? Is like DXF is the biggest kept secret in the world πŸ˜„)))
          Googling 'dxf reference guide' return lots of interesting hits - e.g. http://www.autodesk.com/techpubs/autocad/acadr14/dxf/dxf_reference.htm
          Also there are several RB file plugins in the PluginStore which do DXF import/export manipulation - so using those as 'cribs' would help too...
          So what more do you want ?
          • dereiD Offline
            derei
            Thanks for this... i did a lot of search, but I guess I used the wrong keywords πŸ˜„) never found this. Thanks a lot.
