    Deleting an Edge knowing 2 points
    4 Posts 3 Posters 539 Views 3 Watching
    • K Offline
      ktkoh
      My Dovetails Tail program sometimes leaves faces that should have been deleted by the pushpull action. I am trying to clean these up by deleting edges for which I know only the end points. I have not been able to find a way to identify the edges knowing only 2 points so I could delete them.
      Keith
        Assuming all of these edges are inside a group.entities context...
        Iterate to extract edges that at least match the length between the points...
        length = point1.distance(point2) poss_edges = group.entities.grep(Sketchup::Edge).select{|e| e.length == length } the_edge = nil poss_edges.each{|e| if (e.start.position==point1 || e.start.position==point2) && (e.end.position==point1 || e.end.position==point2) the_edge = e break end }
        Now you have the edge with a starts|end matching the two points.
        If you gave a number of pairs of points as an array of two element arrays, then iterate those in turn:
        ` points.each{|ps|
        point1=ps[0]
        point2=ps[1]
        length == ###..... etc
        etc
        • Dan RathbunD Offline
          Dan Rathbun
          Here is TIG's code altered a bit, and wrapped in a method:
          def find_edge(
            ents,   # a Sketchup;;Entities collection
            point1, # a Geom;;Point3d for start position
            point2  # a Geom;;Point3d for end position
          # Returns the first matching edge found, or nil if no match.
            possibly = ents.grep(Sketchup;;Edge).select {|e|
              e.length == length
            found = possibly.find {|e|
              spt = e.start.position
              ept = e.end.position
              (spt==point1 && ept==point2) ||
              (spt==point2 && ept==point1)
            return found # nil if no match
          • I prefer the boolean finding test to ensure that point1 and point2 are both matched to the iterator edge e, in order to return a true match.
          I'm not here much anymore.
          • K Offline
            ktkoh
            Thanks TIG and Dan
            I applied the code to the Tails part of my Dovetail Tool and now the result is a part with tails that is still a solid. No left over edges or faces.
            The strange thing was that when selecting the component edges if you selected them clockwise (edge1 to edge2) the part was clean but selecting in a counter clockwise direction there were left over faces. Now thanks to your help edge selection direction works either way.
            Keith
