    Creating Uniform Animation
    5 Posts 3 Posters 441 Views 3 Watching
    • A
      adr0427
      Hi I am trying to animate a model. I take scenes and play them as animation. But it some times lingers a bit. Like a shaky video, its because of the inconsistency of taking the scenes one after the other. How can I fix this are there any ideas you guys have got?
      Please provide me with your suggestions from your experiences.
      Thanks! πŸ˜„
      • jujuJ
        juju
        this plugin will help
        File Not Found
        (www.smustard.com)
        • A
          adr0427
          Juju, I just got an idea. What if I put a line constant and fix a view for every scene and turn that line's layer off. It work right? Also the software according to that description only delays or increases time. Is it worth the money. Please if you can show me a sample that would be of great help. THANKS!
          • jujuJ
            juju
            these plugins will probably also be of some help, take a look and see
            http://www.smustard.com/script/FlightPath
            http://www.smustard.com/script/FlightPath2
            http://www.smustard.com/script/CameraControls
            http://www.smustard.com/script/CameraDistance
            http://www.smustard.com/script/CameraLines
            http://www.smustard.com/script/NoteCameraPoint
            adr0427: your idea could work, just remember to check scene settings before saving a scene, typically a newly generated scene will inherit the scene properties (except for the view / orientation) of the current scene (if it is the last scene created).
            • D
              driven
              add a gif of what's going wrong to make it easier to advise...
              e.g.the animations params on this are both 0
              john
