    Terrainmodelling from flat ISO-Lines ?
    2 Posts 2 Posters 259 Views 2 Watching
      Alain
      I have a few flat ISO-lines from a dwg-file, see here:
      Their height in z-direction is zero.
      It there a tool/way to distribute their height regular in z-direction (without touching every line separatly) ?
      My idea is:
      I could first group lines that are at the same height (because some iso-lines of the same height are splited/interrupted at the moment).
      Then select all lines an scale them in z-direction to the height of the heighest iso-line.
      This results in a regular height between all iso-lines.
      But scaling an object without a height seems to be impossible.
      Does somebody know how to do that ?
      Kind regards
      Alain
      • sdmitchS Offline
        sdmitch
        Why not just move the group to the proper Z then explode the group.
        You might also try my Move2Elev plugin.
        http://sdmitch.blogspot.com/
