    Random length siding or decking - plugin?
    7 Posts 2 Posters 518 Views 2 Watching
    • U Offline
      unearthed
      Hi, A client has asked me to design a modular house (I'm just doing the shell) and we're going to build 26 of them (yey), So I came up with the idea of cladding them in vertical random-length boards, something like images here http://www.archdaily.com/674/co2-saver-house-peter-kuczia/02-detail-south-west-phot-t-pikula/ and attached.
      Like Peter Kuczia I will probably mix in boards of different colors/materials, even very narrow feature windows as views to South are great but South is Antarctica too, brrrr.
      So has anyone built a plugin to place boards of a random length on a surface?
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
      • sdmitchS Offline
        sdmitch
        Yes, try my FloorGenerator plugin on my blog or in the Plugin Store. Don't let the name fool you, its really more a pattern generator and works on horizontal or vertical faces.
        http://sdmitch.blogspot.com/
        • U Offline
          unearthed
          Thank you sdmitch, I think that'll do me nicely, But would it be possible to add a seed/minimum length to the length box? As this will be wood siding on a house I'm probably looking at a minimum length of ~400mm
          I've watched the vid and think this tool could also do some planting plans, I'll do a separate post and ask you there
          • sdmitchS Offline
            sdmitch
            Currently, if Fixed Length is unchecked, the maximum length is the length entered and the minimum is 75% of that.
            • U Offline
              unearthed
              Thanks, so when I poked around in the code, the only two .75 instances i found were:
              Line 458: end until tx>=dx0.25 && tx<=dx0.75
              Line 463: end until tx>=dx*0.75
              So I suppose if I tweak those I can get a shorter minimum length - I will play tomorrow [it is tomorrow as I couldn't sleep]
              • sdmitchS Offline
                sdmitch
                Line 458 controls the length of the starting "board"
                Line 463 is the one that controls the minimum length
                • U Offline
                  unearthed
                  Thanks very much sdmitch, I'm not a coder at all, but even failing a programming degree has proven useful, also Notepad++ very helpful for find code bits
                  I can now go and roll this idea across a subdivision and all will look nicely loose and random
