Random length siding or decking - plugin?
Hi, A client has asked me to design a modular house (I'm just doing the shell) and we're going to build 26 of them (yey), So I came up with the idea of cladding them in vertical random-length boards, something like images here http://www.archdaily.com/674/co2-saver-house-peter-kuczia/02-detail-south-west-phot-t-pikula/ and attached.
Like Peter Kuczia I will probably mix in boards of different colors/materials, even very narrow feature windows as views to South are great but South is Antarctica too, brrrr.
So has anyone built a plugin to place boards of a random length on a surface?
Yes, try my FloorGenerator plugin on my blog or in the Plugin Store. Don't let the name fool you, its really more a pattern generator and works on horizontal or vertical faces.
Thank you sdmitch, I think that'll do me nicely, But would it be possible to add a seed/minimum length to the length box? As this will be wood siding on a house I'm probably looking at a minimum length of ~400mm
I've watched the vid and think this tool could also do some planting plans, I'll do a separate post and ask you there
Currently, if Fixed Length is unchecked, the maximum length is the length entered and the minimum is 75% of that.
Thanks, so when I poked around in the code, the only two .75 instances i found were:
Line 458: end until tx>=dx0.25 && tx<=dx0.75
Line 463: end until tx>=dx*0.75So I suppose if I tweak those I can get a shorter minimum length - I will play tomorrow [it is tomorrow as I couldn't sleep]
Line 458 controls the length of the starting "board"
Line 463 is the one that controls the minimum length -
Thanks very much sdmitch, I'm not a coder at all, but even failing a programming degree has proven useful, also Notepad++ very helpful for find code bits
I can now go and roll this idea across a subdivision and all will look nicely loose and random
