    Revit to sketcup - curved surfaces?
    2 Posts 2 Posters 322 Views 2 Watching
    • J
      Jorgensen
      hi
      i wonder if the there is a way to adjust the smoothness of curved faces imported from revit?
      i export from revit as dwg > solids > acis solids to sketchup, but i have not found a way to adjust the roundness of curved walls ect.
      have i just overlooked this option or does it not exists?
      thanks πŸ˜„
      jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • oceanembersO
        oceanembers
        There are several plugins that could help you. fredo's bezier spline and thomthom's bezier surface spring to mind, and will give you the functions you need in this instance.
        Unfortunately, Sketchup does not have any native support for curves, so there won't be a way to bring in the models and keep 100% of the editability they had in revit.
