    Revert back to saved version
    8 Posts 4 Posters 4.2k Views 4 Watching
      driven
      Sketchup.undo
        Encapsulate your 'animation' code thus:
        Sketchup.active_model.start_operation("MyLovelyAnimation")
        do your transformation stuff, using Sketchup.active_model.refresh etc as needed...
        afterwards, to reset everything back to where you started, use...
        Sketchup.active_model.abort_operation
        everything is then undone in one go.
        • Dan RathbunD Offline
          Dan Rathbun
          ... but does he have to use transform! instead of move! inside the operation block ?
          I'm not here much anymore.
            If he's does pure 'animation' using move! instead of transform!, it will indeed not add things to the 'stack'.
            But if he is also changing layer visibility etc, then that is ?
            Aborting the operation will reset back to how it was before the start...
            Although if he's animating the camera, he is advised to save the active view's camera immediately before starting the operation, and after aborting it to reset the view camera back to that ?
              slbaumgartner
              Seems like maybe a lot of the posts have dodged the original question: when you revert a file, you close the current version and reload the saved one from disk. Can't this be done via:
              # true says ignore changes and suppress the save dialog
              Sketchup.active_model.close true
              Sketchup.open_file(path_to_file)
                Dan Rathbun
                Yes but this will work only on SketchUp 2015+
                close(true) = ignore changes and suppress the save dialog
                filepath = Sketchup.active_model.path
                if Sketchup.active_model.respond_to?(;close)
                  Sketchup.active_model.close(true)
                elsif RUBY_PLATFORM !~ /darwin/i # NOT OSX
                  Sketchup.file_new
                Sketchup.open_file(filepath)
                  Dan Rathbun
                  TIG's Encapsulate your 'animation' code is really a better idea.
                  But try it like this (he omitted the need for a commit_operation call.)
                  begin ### do everything in one go;
                      ### Do your transformation stuff, using
                      ### Sketchup.active_model.refresh etc as needed...
                    Sketchup.active_model.commit_operation
                  rescue => e
                    # Just output any exception info to console;
                    puts "Error; "<<e.inspect
                    puts e.backtrace # optional
                  else
                    # Things to do only when NO errors occur;
                    UI.messagebox("The show is over. Reset now?")
                  ensure
                    # Whether or not any errors occur;
                    ### reset everything back to start
                  I am not sure if the messagebox will actually cause a pause before reset.
                    Going back several steps .move! works like .transform! without affecting the stack within an animation ?
