    Group moves far away when i want to scale
    4 Posts 4 Posters 646 Views 4 Watching
    • Y
      YoungOSG
      t = Geom::Transformation.scaling 2
      group.transform! t
      i use above code to scale s group,however the group always move far away!
      I can not figure it out.
      anyone helps!! thanks!
      • Dan RathbunD
        Dan Rathbun
        Check where the origin of the group is. The scaling is relative to the group's origin.
        I'm not here much anymore.
        • TIGT
          To scale it about it's center use three scaling values and a point
          t = Geom::Transformation.scaling(2, 2, 2, group.bounds.center) group.transform!(t)
          • tt_suT
            tt_su
            There is an issue with this method - it doesn't produce the same transformation as
            Geom::Transformation.scaling(2, 2, 2)
            The former change the 16th value in the matrix - instead of scaling the components.
            I'm not sure why it was implemented as such, but several render engines have had issues with that. I think even SU have issues in some cases. Think we have an issue filed to change it.
