    Group moves far away when i want to scale
    4 Posts 4 Posters 511 Views 4 Watching
    • Y Offline
      YoungOSG
      t = Geom::Transformation.scaling 2
      group.transform! t
      i use above code to scale s group,however the group always move far away!
      I can not figure it out.
      anyone helps!! thanks!
      • Dan RathbunD Offline
        Dan Rathbun
        Check where the origin of the group is. The scaling is relative to the group's origin.
        I'm not here much anymore.
          To scale it about it's center use three scaling values and a point
          t = Geom::Transformation.scaling(2, 2, 2, group.bounds.center) group.transform!(t)
          • tt_suT Offline
            tt_su
            There is an issue with this method - it doesn't produce the same transformation as
            Geom::Transformation.scaling(2, 2, 2)
            The former change the 16th value in the matrix - instead of scaling the components.
            I'm not sure why it was implemented as such, but several render engines have had issues with that. I think even SU have issues in some cases. Think we have an issue filed to change it.
