    Dividing welded arcs!
    6 Posts 4 Posters 695 Views 4 Watching
    • mtripleM
      mtriple
      lets say i have 2 or more connected arcs with different segments for the same length,
      these arcs create me a shape or circle, when i give it a height value, thiss how its look like :
      http://i375.photobucket.com/albums/oo199/mtriple1/asd_zpsml1zhmjm.jpg
      you can see the segments differ.
      now for exporting or dealing with other programs this object must be divided equally.
      is there any idea or plugin , program that divide this welded curve to equal segments.
      i know i can divide each arc separately, but my shape is likely 20 arcs with different length and its hard to find the value for dividing each one.
      also after welding the arcs, they become either one connected curve or an edges(after exploding).
      compospray workin 2014
      • mitcorbM
        mitcorb
        Hi:
        I thought TIG had developed one and it should be in the pluginstore. Possibly also Fredo6. It has been a long time.
        • D
          driven
          Fredo 'Bezier Spline' tools has the ability to set the spacing
          If you have a curve, generated by BezierSpline or from native Sktechup, you can convert it to a Polyline with equal segments by 2 methods which are delivered as part of BezierSpline (via the contextual menu "Convert to":
          1. Polyline Divider: you specify the interval, and the extension computes the number of segments
          2. Polyline Segmentor: you specify the number of segments, and the extensions computes the length of segments
          Note that all segments will be equal, except possibly the last one (but you can adjust the last vertex anyway).
          • mtripleM
            mtriple
            i found way but its long. i will post it later.
            do u have links or plugins name ?
            • cottyC
              cotty
              'Bezier Spline' isn't enough name?
              Here's the link... http://sketchucation.com/pluginstore?pln=BezierSpline
              my SketchUp gallery
              • mtripleM
                mtriple
                ohh thank you for the link.
                when i googled it i found Bezier Curve, that was the mistake.
                very helpful plugin 'Bezier Spline'.
                thank you.
                what i was doing is using 1001bit to redivide by placing guide points, then i use connect guide point plugin.
