    [Plugin] TIG-LayersFromList
    26 Posts 7 Posters 4.4k Views 7 Watching
    • jujuJ Offline
      juju
      wow, should be a real great thing if the two were to be combined
        Here is v1.2 http://sketchucation.com/pluginstore?pln=TIG_LayersFromList
        It fixes an issue reported by some Win8 users, where the layers' color were not getting set correctly.
        • Miner_JeffM Offline
          Miner_Jeff
          Hi Folks,
          If you need to create a sequence of layers with text and numbers with specific colours I have shared a means to create the text file easily for use with this wonderful ruby of TIG's.
          It can be used to verify the colour of RGB values too by colouring the cell to RGB values specified.
          I used MS excel and VBA. It can be found here http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=63894
          Cheers,
          Miner_jeff
          • sumasterS Offline
            sumaster
            Can we set Default Text file path in this script . . . . . ?
            Thank you,
            SUmaster
              Please expand on this, so we might understand your question...
                db11
                Hi TIG -
                Thanks for a very useful plugin (along with it's companion).
                I have a request for a plugin that would build on these two, in order to automatically replace Layers From with Layers To in a SU file. My thought is that the easiest way would be with a simple two column csv file that gives the equivalences: 'From' in col A and 'To' in col B.
                I would use it to harmonize layer names across models, so that imported components would always land on the right layers, without having to manually delete and merge the newly imported layer(s).
                Not sure how difficult it would be, but would be a great help.
                Thanks,
                Doug
                • 2 / 2
