    Vray material for a wooden beam (help?)
    2 Posts 2 Posters 1.8k Views 2 Watching
    • F Offline
      fvweert
      Hi guys,
      I made a high poly model of a wooden beam with a rope around it.
      I want to make a close-up of it with vray.
      Download:
      https://drive.google.com/file/d/0B8zJtNz88Nk9VU84SEwxbTZvbVk/view?usp=sharing
      The problem is that I can't make the textures (positioning and adjusting the material for vray).
      The wood has to have a vintage look, with a luxurious feel. Maybe Oak or Teak wood-like.
      The texture I used is not the texture I want by the way, consider it work in progress.
      Maybe someone could help me? I'm not an expert at this.
      Would be awesome!
      Regards,
      Frank
      • hellnbakH Offline
        hellnbak
        Wow, 259MB!!! ๐Ÿ˜ฎ ๐Ÿ˜ฎ While I admire your incredible attention to detail, you might consider figuring out how to make do with using a component for the rope vs groups. After all, unless the rope is glued to the beam, would it really follow every contour of the beam?
        This is not meant as a criticism, your modeling skills are impressive to say the least, just a suggestion.
