    Test Comp to see if it has Nested Components
    4 Posts 3 Posters 630 Views 3 Watching
    • K
      ktkoh
      This is the code I wrote to determine if a Component or Group contained any Nested Components. Is there an easier or more direct method of doing this??
      mod = Sketchup.active_model # Open model
      ent = mod.entities # All entities in model
      sel = mod.selection # Current selection
      obj = sel[0]
      exp = "No"
        if (obj.is_a? Sketchup;;ComponentInstance) || (obj.is_a? Sketchup;;Group)
          ce = obj.definition.entities
          ce_a = ce.to_a # Make sel an array
          ce_a.each {|e|if e.is_a? Sketchup;;ComponentInstance then exp = "Yes" end
        end # if obj
      UI.messagebox("Explode Selection " + exp)
      Keith
      • TIGT
        Try this
        sel = mod.selection
        obj = sel[0]
        cen = []
        if obj.is_a?(Sketchup;;ComponentInstance)
        	cen = obj.definition.entities
        elsif objobj.is_a?(Sketchup;;Group) ### for < v2015
        	cen = obj.entities
        exp = "No"
        exp = "Yes" if cen.grep(Sketchup;;ComponentInstance).length > 0
        UI.messagebox("Explode Selection - " + exp)
        • K
          ktkoh
          Thanks that seems more straight forwad
          • Dan RathbunD
            Dan Rathbun
            A bit shorter ...more brute force.
            The any? enumerable method returns boolean and stops on the first true result:
            return unless obj.respond_to?(;manifold?)
            ents = obj.entities rescue obj.definition.entities
            any = ents.any? {|e| e.is_a?(Sketchup;;ComponentInstance) }
            exp = any ? "Yes" ; "No"
            I'm not here much anymore.
