    A wooden ladder
    7 Posts 5 Posters 1.2k Views 5 Watching
    • cottyC Offline
      cotty
      A simple wooden ladder with dovetail joints...
      You can download the model here.
      my SketchUp gallery
      • bazB Offline
        baz
        Sorry Cotty, from a real world technical viewpoint this will not work, you have opposing grain direction. The natural movement of the timber will break this quite quickly.
        • cottyC Offline
          cotty
          Thanks for the info, now I'm happy that it wasn't designed to be build πŸ˜‰
          my SketchUp gallery
          • bazB Offline
            baz
            Well that raises an interesting question. Design is design whether 'real' or not.
            To make an analogy with writing, if a work of fiction purports to be fact, does that make it fraud? Or say Architecture, if you design a building which is inherently unsound, is that ok?
            Or am I being pedantic?
            • HornOxxH Offline
              HornOxx
              @ baz :
              ...not necessarily pedantic - but very philosophical in any case πŸ˜„
              Hi Cotty,
              I tried to achieve the same or at least a similar warm wood-look - as you always get it to the point. I had a long tinkering with the lighting until it worked.
              Very good is your trick to hover the model a little above the ground, so that the model does not look like glued there. Thanks for sharing!
              Shaderlight Render
              never trust a skinny cook
                Thanks, very kind of you.
                • Bryan KB Offline
                  As always, looks great!
