Plugin Failure on 2014 upgrade
I am having major plugin issues with 2014. I have moved my previous plugins to the correct folder, but I am still getting and error message on startup that the plugins have failed to load. However, once I close the message window, some plugins work and some don't.
Also, the plugin manager fails to connect to the plugin store.
Any ideas?
Thanks.
a large majority of SU v8 plugins will fail on v2014, there are many post telling you NOT to do what you just did...
remove them all, then re-download the updated SCF plugin manager and only bring in others that are updated for v2014...
any you can't find updates for, bring in one at a time and test them...
john
Where do I find the updated SCF manager?
Thanks.
Ah! Found it. Thanks again.
That worked. Still had to go to the website as the manager connection was slow, but it worked.
Thanks again john.
Register LoginAdvertisement
