    Volume is wrong when reversed faces are present!
    46 Posts 10 Posters 5.6k Views 10 Watching
    • fredo6F Offline
      fredo6
      @Ken,
      I also fixed this one, thanks for signaling.
      New release in FredoTools v2.7d
      Fredo
      • kenK Offline
        ken
        fredo6
        Thanks that did the trick.
        Ken
        Note, volume isn't everything, I require the weight of a filled container. I have taken one of TIG's volume plugin and added the math to determine the weight of the volume; oil, water, buoyancy salt water, buoyancy fresh water, river mud, concrete, wet river gravel, and barrel of oil. Had a great time in the learning process of modifying a plugin.
        fredo6, thanks for this plugin. And thank you TIG.
        And not to highjack this thread, your movealong plugin is absolutely fantastic.
        • fredo6F Offline
          fredo6
          I can easily add an additional section to give the weight for a number of materials in several units.
          Fredo
          • kenK Offline
            ken
            fredo6
            Thank you for the offer, however I believe that would be a lot of work that wouldn't be of use to most Sketchup user. To give you an idea of my list:
            Barrels of Oil (Note there is only 42 gallons)
            lbs Steel (A36)
            lbs SS304
            lbs Brass
            lbs Aluminum
            lbs zinc
            lbs Lead
            lbs Gravel Wet
            lbs River Mud
            lbs Sand Water
            FW buoyany 62.4 lbs/cuft - Fresh Water
            SW buoyancy 64.1 lb/cuft - Salt Water
            lbs Crude oil
            This list has been modified or added to as required. So I don't see how a set list would cover all the variables. Now a user input section would be nice, if it held the variables between sessions. Still a lot of work for a very few.
            On another note, if you look at the image, you will see that the bottom part of your form is not being displayed. Maybe the box should be a little taller.
              The free fabulous Designspark Mechanical (SpaceClaim Light) has this inside its library as Volumic Mass 😉
              (my French Page(s) about this SU on Steroïds 😉
              • fredo6F Offline
                fredo6
                Just a reasonable work, in hours, to add the feature with a custom editable list.
                I fixed the problem in Fredotools v2.7e.
                Fredo
                • 3 / 3
