    Display distortion
    5 Posts 4 Posters 2.9k Views 4 Watching
    • L
      lbertaux
      I'm having my model display distort when enlarging. Nothing will correct it short of closing out and reloading the file. Anyone seeing this? SU2015 Mac Pro OS X 10
      • D
        driven
        I'm, really, not grasping what you mean...
        can you go through your steps...
        add a before/after image, or anything that clarifies what your referring to...
        john
        • JQLJ
          JQL
          If it is a component inside your model, try resetting scale.
          www.casca.pt
          Visit us on facebook!
          • S
            slbaumgartner
            Are you perchance using the Scale tool and dragging one of non-corner handles to "enlarge"? The non-corner handles resize in one or two axes at a time, which will distort shapes in your model. Only the corner handles scale all three axes the same.
            • JQLJ
              JQL
              If you insert a component/group inside other component/group and rotate the inner comp/group and scale the outer comp/group it will skew the inner group. If you save the inner group with this skewed scale into an external file and assume that scale (SU asks what you want to do) you'll get some funky component. When you reload it into the model, that funky component will be scaled and skewed again, becoming even funkier. That can go on and on until the funkiest unlimited possibility. 😎
              www.casca.pt
