    Texture change position when ungroup
    3 Posts 2 Posters 2.9k Views 2 Watching
    • alexandre skA
      alexandre sk
      texture change position when ungroup.
      When it is inside a component a change a texture position, using the OEM tool, when explode the component some textures change position a little, but enough to ruin my work.
      sketchup pro 2014.0.4900
      Anyone has see this?
        I haven't seen it. if the material is applied the the faces in the component. It can happen if the materials are applied to the component wrapper instead of the faces inside. If the position or orientation of the material is important to you, you should be painting the faces, not the wrapper.
        • alexandre skA
          alexandre sk
          Well I paint the faces not the wrapper always. I found that it occurs when I use the pain bucket inside the group and don't move the texture. Then when I ungroup it changes, and the faces that i have manually positioned the texture stay correct.
          It is not a huge problem but makes me ungroup before texture it. I have to change to 2015 anyway.
          Thanks for the reply Dave.
