    Assign new layer name quickly?
    13 Posts 5 Posters 874 Views 5 Watching
    • onzkiO Offline
      onzki
      Hi everyone, is there a way to assign new layer name quickly, like in two basic steps or mouse clicks?
      Usage example:
      Step 1: right click an object, sub menu appears,
      Step 2: then choose "send to new layer"- and then you type in the new layer name, press enter.
      This plugin as usual, will consequently have a one click icon/button or assignable with keyboard shortcut.
      As comparison, presently, what I usually do is:
      Step 1. open the native layers tab (I have shortcut key)
      Step 2. click +
      Step 3. Type the name
      Step 4. Select object
      Step 5. activate entity info (I have shortcut key)
      Step 6. Choose the new layer name created from step 3
      So that's it.. 2 steps vs. 6 steps.
      Thanks a lot for looking at this. Cheers! πŸ˜„
      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
      • Bob JamesB Offline
        Bob James
        Plugin not included 😞
        Also to match the naming convention please change the name to [Plugin] Assign New Layer Name
        Otherwise it looks like a very useful idea πŸ˜„
        • pbacotP Offline
          or type a new layer name into the entity window?
            I think that you can do that on MAC, but you can't on a PC...
            • pbacotP Offline
              OK two steps then. Buy a Mac and type the layer name into the entity window. πŸ˜‰
              • sdmitchS Offline
                sdmitch
                Usage example:
                Step 2. click +
                No icon or shortcut needed. Simply place copy of the following code in the Plugins folder, restart Sketchup. Then right click on any entity and select "Send To New Layer"
                unless file_loaded?(__FILE__)
                	mod = Sketchup.active_model
                	ent = mod.active_entities
                	sel = mod.selection
                	UI.add_context_menu_handler do |menu|
                		unless sel.empty?
                			menu.add_separator
                			menu.add_item("Send To New Layer") {
                				obj=sel.first
                				ln=UI.inputbox(["Layer Name"],[obj.layer.name],"Send To New Layer")
                				if ln
                					nl=mod.layers.add ln[0]
                					nl.name = ln[0]
                					obj.layer=nl
                		end#unless sel
                	end#do
                	file_loaded(__FILE__)
                end#file
                http://sdmitch.blogspot.com/
                  I have something similar, running from the context-menu, although it allows you to specify a layer that is 'off', entering a new layer creates it OR you can choose from a drop-down list of all Layer-names.
                  I'll post it in the PluginStore and add a link...
                  EDIT:
                  Here's the link to its thread...
                  http://sketchucation.com/forums/viewtopic.php?p=563979#p563979
                  • onzkiO Offline
                    onzki
                    Thanks everyone for all your replies, I appreciate the help. I will check them out. Cheers!
                    • onzkiO Offline
                      onzki
                      EDIT:
                      Oh, I never found this on search. It's perfectly what I'm looking for, the existing layer list is also a bonus for me. Thanks for sharing!
                      • onzkiO Offline
                        onzki
                        @sdmitch said:
                        [/code]
                        Another useful one, now I got not only 1 but two.. yours and TIG's, it's great! Thanks!
                        • onzkiO Offline
                          onzki
                          EDIT:
                          By the way TIG, I noticed that the list of existing layers won't allow me to scroll down to see more layers- is there a new version that can scroll along the list?
                            This is a known limitation of the UI.inputbox drop-down list.
                            However, it is not insurmountable...
                            To pick a layer-name that is off the end of the list...
                            Select the drop-down box so it highlights, immediately type in the start of the layer name [DO NOT press <enter>] - e.g. X
                            The listing now jumps to show perhaps " Xref-1"
                            If you want " Xref-3" press the down arrow key to page to it.
                            If you want " Wins" and are currently at " Xref-1" then use up arrow key presses to get to it...
                            • onzkiO Offline
                              onzki
                              Works like a charm! Thanks a lot! πŸ˜„
