    Make Unique Texture
    4 Posts 3 Posters 724 Views 3 Watching
    • masterpaulM Offline
      masterpaul
      The built in make unique texture is terrible; compresses the images, makes them smaller and saves them in jpeg even if the original was png or another format.
      I tried using make unique texture ++ however it does not work in the newest version of sketchup (Error #<NoMethodError:undefined method `+' for nil:NilClass.>)
      My whole texturing and modelling process revolves around making textures unique and adding detail to them by hand in photoshop/gimp. However the quality is shredded by sketch-ups default make unique function. This is not a problem on smaller textures or textures that are rough in nature however if you start playing around with larger textures or smoother textures; then you will start noticing horrible artifacts.
        roland joseph
        If you are using "large textures" (windows/preferences/opengl) Your max size is 2048. So yes your textures get compression. To keep the detail in place I break the image into pieces with "make unique". I am painting buildings and ground so my original images are never bigger than 16000X16000. I can easily pick out a door or window or special feature in the image and ad mesh there so that I can then turn that separate area into a unique image.
        Otherwise I swap out the low res imaqe for high rez in my rendering app which is happy to devour textures up to 16000x16000.
          masterpaul
          They get compressed even with textures smaller then 2048. I'm using a simple texture that's basically a smooth gradient from grey to white; that's why perhaps all the artefacts show so much.
          Is there away I could stop SketchUp from saving it as jpeg?
            Just use it to create a new one with a different name in the Materials editor.
