    Project Image
    3 Posts 2 Posters 361 Views 2 Watching
    • ntxdaveN
      ntxdave
      I am running into a problem I do not seem to be able to solve.
      I need to project the image in the screen capture below onto the object just below it. Since I have used Shape Bender to curve the object in two different directions, I cannot seem to apply the image as a texture properly. I have also attached an SKU file that has the two object to see if someone can help me.
      Yes, I know the quality of the image is not that great but it will work for what I am doing.
      Projection Imgae.skp
      Press F1...thank me later
        • ntxdaveN
          ntxdave
          Thanks Pilou, that was the video I was looking for and did not find. After creating some better images to project, I was able to get it done. Here is an image of how it finally turned out....
          Notice that I actually had to make two copies because of the orientation. The original image that I was using just did not work well at all (was a photograph that was taken at an angle).
          It sure isn't perfect but it is close enough for how it is being used and a huge step forward from what I originally had.
          Once again, thanks for the reply..........
