    Whitebeam trees
    12 Posts 6 Posters 10.5k Views 6 Watching
    • PixeroP Offline
      Pixero
      I've added three detailed Whitebeam trees (Sorbus intermedia) (Oxel in Swedish) made with The Plant Factory to the Sketchucation store: http://sketchucation.com/shop/models/landscape/1421-whitebeam-trees
      The trees are about 6 meters high.
      Render ready for Thea.
      OBJ files and textures included for other render engines.
      Each tree has approx 280.000 polygons.
      Please observe that there is no skp files in this pack.
      Click the images to view large size.
      This is how they look without any leaves.
      And here is a detail image.
      Now updated with skp files with face me components for better preview.
      As a bonus I've also included a special version of tree 01 with displaced geometry on trunk (for closeups).
      For previous buyers:
      If you provide me with a proof of purchase I'll send you the update at no extra cost.
      • pbacotP Offline
        Really nice looking! When I can get back to rendering...
          Very nice, Jan. Thank you for sharing them.
          • PixeroP Offline
            Pixero
            • PixeroP Offline
              Pixero
              v.1.2 fixes missed texture in install.
              To install just unzip and double click on the lib.thea file and the installer will install everything in the correct place.
              • bazB Offline
                baz
                Just bought the pack from the store, but there is no skp file in there?
                Baz
                • PixeroP Offline
                  Pixero
                  The skp face me components are installed by the lib.thea in the same directory as the Thea proxies.
                  If you place a proxy the face me component will appear as a preview in SketchUp.
                  • bazB Offline
                    baz
                    Bugga, I don't use thea, I was just wanting the skp. 😞
                    • PixeroP Offline
                      Pixero
                      Since they are very polygon heavy (Each tree has approx 280.000 polygons.) they are not really suited to be directly imported into SketchUp.
                      I have included obj files for use with other render engines and they might be possible to import if you really want to.
                      • bazB Offline
                        baz
                        Thanks, will put that one down to experience.
                        • KrisidiousK Offline
                          Krisidious
                          great work Pix...
                          By: Kristoff Rand
                          • H Offline
                            hazzrael
                            hi all , i have the same problem with faces when i import the tree in obj file , so i use plugin "UV toolkit2" from tomtom .... 1 select the object /2 go to extention uvtoolkit select "front face material to back face" wait 2 minutes and the tree is OK - but u have to do materials yourself (bump and specular)(i use vray 2.0) but it's easy all the maps are included... enjoy
