    Settings resets back
    2 Posts 2 Posters 380 Views 2 Watching
    • K Offline
      Kaylle
      When I start Sketchup, I do this: View > Edge Style > uncheck Profile
      Because the lines surrounding a figure/entity is thick but when I close Sketchup, it's back again. How do I make it permanent?
      It wasn't like that before if I didn't made a big mess with Sketchup.
      Also, the color became yellow, normally it's bluish.
      I'm using WinXP 32bit and an old Sketchup 8.0.11752 free ver.
        You need to modify the template you are using as the default. Open a fresh SketchUp session. Make the desired changes to Profiles (set them to 1 if you don't like the heavy edges but leave Profiles turned on) and change colors to suit. I'm not sure what you are referring to as yellow and bluish but all colors can be modified. Make sure you update the style by clicking on its thumbnail in the upper left corner of the Styles window. Then use File>save as template... to save the new template. Make sure Use as default is ticked. From then on, when you open SketchUp, it should look the way you want it to look.
