SU Pro 2015 dwg export.
In 2015 when you export a dwg of a plan as a dwg (not a section slice) it exports all the geometry, not the view you have. If you have people it doesn't just give their outline, it gives all the geometry within the model.
Has anyone else experienced this? is it an option I'm missing?
OK - so no replies. Perhaps I haven't explained myself.
Here are two .dwg 2D Graphic exports of an identical file. Both used the default settings.
Here is the export using SketchupPro Version 8
Here is the same export using SketchupPro 2015
As you can see the 2015 shows all the geometry.
I use this export daily and unless someone has a solution it will force me to return to Pro 2008 version and I won't bother updating t any further versions of this program.
These are both 2d exports?
yes - vertical view, parallel projection. Export/ 2D Graphic/.dwg
Ok - I've found the problem - following a suggestion in another thread about crashes I turned off hardware acceleration and the problem was fixed!!
Could you please pass it on to Trimble.
Register LoginAdvertisement
