    SU Pro 2015 dwg export.
    5 Posts 2 Posters 2.5k Views 2 Watching
    • John SayersJ Offline
      John Sayers
      In 2015 when you export a dwg of a plan as a dwg (not a section slice) it exports all the geometry, not the view you have. If you have people it doesn't just give their outline, it gives all the geometry within the model.
      Has anyone else experienced this? is it an option I'm missing?
      so I export this
      and get this
        John Sayers
        OK - so no replies. Perhaps I haven't explained myself.
        Here are two .dwg 2D Graphic exports of an identical file. Both used the default settings.
        Here is the export using SketchupPro Version 8
        Here is the same export using SketchupPro 2015
        As you can see the 2015 shows all the geometry.
        I use this export daily and unless someone has a solution it will force me to return to Pro 2008 version and I won't bother updating t any further versions of this program.
        • pbacotP Offline
          These are both 2d exports?
            John Sayers
            yes - vertical view, parallel projection. Export/ 2D Graphic/.dwg
              John Sayers
              Ok - I've found the problem - following a suggestion in another thread about crashes I turned off hardware acceleration and the problem was fixed!!
              Could you please pass it on to Trimble.
