    Get layers in layer window to display alphabetically?
    5 Posts 4 Posters 369 Views 4 Watching
      CalypsoArt
      I'm working on a large model and need to use a lot of layers. For some reason they do not display alphabetically. Any way to do this. My Autocad automatically rearranges the layers.
        Calstock
        I can't help you specifically on this one, but a tip that may help you or others is I have my template set up with a numbered layer menu that suits my garden design work, (see attachment).
        The beauty of using a numbered system, 01, 02, etc. is that you very quickly become familiar with how all your usual layers are ordered. Secondly you can add linked layers, so 03 -House might have 03a - Outbuildings, 03b - Garage block, etc. added on some models - keeping all the "building" layers grouped together. Finally, if you download models from 3D Warehouse and elsewhere, (like Formfonts), the layers they sometimes annoyingly add to your model are listed after all your numbered layers and so don't clutter the list up.
        I hope that helps someone !
        • sdmitchS Offline
          sdmitch
          In Windows>Layers, the names should be sorted. If not, click on Name at the top of the names column. This will toggle between a-z and z-a sorting.
          http://sdmitch.blogspot.com/
            CalypsoArt
            Duh! I feel like an idiot. That's how files get ordered and so many things. I think I've been looking at this screen for too long. A walk is in order.
            Thanks!
            • Bob JamesB Offline
              Bob James
              When you recover from your massive "duh" (welcome to the club), Calstock's advice is still very good.
