    How to export model info as .csv files using ruby console?
    5 Posts 3 Posters 800 Views 3 Watching
      db11
      I want to be able to export (as .csv) simple lists of model info such as styles / scene names etc with a Ruby code snippet.
      I'm sure it must be quite straight forward, but I'm clueless with Ruby. (though I would like to start learning it).
      What I need at the moment is just a code stub that will generate the csv file from one class of model info — right now I need the style names — and I can swap out the different methods for other info once I understand the basics.
      Anyone have a starting point for me?
      Thanks,
      Doug
      • oceanembersO Offline
        oceanembers
        I can't help you with the code, I don't know Sketchup's API very well at all, but as for a starting point for learning...
        http://learnrubythehardway.org/book/
        I used this to learn the basics of ruby, and I thoroughly reccomend it.
        • G Offline
          Garry K
          This script creates a simple plugin that traverses your model and creates a csv file
          csv from styles
            db11
            That's great Gary — does exactly what I want. Many thanks,
            Doug
              db11
              Starting to learn Ruby is on the to-do list once I'm through my current set of deadlines. Thanks for the link and the recommendation. I'll check it out.
