    Required tutorial for aligning objects
    6 Posts 5 Posters 641 Views 5 Watching
    • john2J Offline
      john2
      I'm having difficulty in aligning a hexagonal pyramid. Simply put, I don't know how to rotate it perfectly any way I want. I searched on youtube but for aligning objects, I'm getting tutorials for cuboidal forms.
      Can anyone suggest me a video tutorial for aligning other geometrical forms easily?
      • S ShepherdS Offline
        S Shepherd
        You could draw some lines on whatever axis you require inside your pyramid group, then put those guidelines on a layer so they can be hidden after you complete your rotations.
        This gif seems a bit shaky for some reason, sorry.
        Shep
          You can also try the Align tool by Didier Bur Where 6 clics are sufficient
          for align any volumes on any things! πŸ˜„
          http://sketchuppluginreviews.com/wp-content/uploads/2010/05/align_tool.gif
          • olisheaO Offline
            olishea
            I draw a line and use perpendicular face plugin to give a surface to rotate from.
            oli
            • panixiaP Offline
              panixia
              you should also try this,works very nice! http://sketchucation.com/plugin/918-s4u_aligntool_v1-0-4
              maybe if you are on sketchup 2015 you may also draw a rotated rectangle and then draw the exagon on face of it..
              • john2J Offline
                john2
                align tool plugin not showing up in sketchup 2014 make. what's wrong?
