    Dimensions LayOut are not the same as in Sketchup
    layout
    5 Posts 3 Posters 1.1k Views 3 Watching
      christophe913
      Hello,
      It seems to be that the dimensions you add in Layout are not matching with the dimensions in Sketchup.
      Please look at the picture below (from Sketchup): the marked dimension is 2mm.
      The 2mm is the correct distance.
      SKETCHUP
      Now, when I send this drawing to Layout and I want to measure the same distance, I got a different dimension: 42mm !
      LAYOUT
      I've tried everything!
      It's a very annoying issue because you cannot rely on Layout's dimensions
      I've read other posts about this issue (i.e. http://sketchucation.com/forums/viewtopic.php?f=12%26amp;t=35652 ), but the problem remains.
      I would appreciate any help!
      Thanks,
      Christophe.
        Could you share the LayOut file? That would make it easier to determine what the issue is. I do all my dimensioning in LayOut and I haven't run into that issue at all.
          sonder
          Check your dimension style, and verify it is on auto, and not set to a specific scale for perspective dimensions.
            christophe913
            Hello Dave,
            Thanks for your reply.
            On following link you can download my Layout-file.
            dimensions not matching.layout
              That link doesn't work correctly. How about just uploading the file here?
