    Check "if view?"
    7 Posts 3 Posters 467 Views 3 Watching
    • CadFatherC Offline
      CadFather
      does anyone know if there is a way to check whether one is aligned to a standard view (current view)?
      tried various combinations, "if view=='ViewTop" etc. there seems to be nothing in the api.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        This will return true if the view is looking straight down (top view)
        if Sketchup.active_model.active_view.camera.zaxis == [0,0,-1]
          Jim
          I like Camera#direction - it's more clear than zaxis.
          Vector3d#parallel? and Vector3d#samedirection? might be better than == since they consider tolerance.
            CadFather
            thanks J, that's promising!
            EDIT: something's moving...! will report back 😆
            yes....just wonderful, all works great.
            Jim, are you trying to scare me? 🤓 😲
            Thanks!
              Jim
              Thanks!
              Not very scary.
              cam_dir = Sketchup.active_model.active_view.camera.direction
              if cam_dir.samedirection?(Y_AXIS)
                # Front
              elsif cam_dir.samedirection?(Y_AXIS.reverse)
                # Back
              elsif cam_dir.samedirection?(X_AXIS)
                # Left
              elsif cam_dir.samedirection?(X_AXIS.reverse)
                # Right
              elsif cam_dir.samedirection?(Z_AXIS)
                # Bottom
              elsif cam_dir.samedirection?(Z_AXIS.reverse)
                # Top
              else
                # Not aligned to Std View
                CadFather
                Jim, that neat way, makes perfect sense..! 😄
                here's the follow up to the previous if anyone has any idea:
                working with this below, all good. but are there not controls for the 'look around' tool as well?
                (nothing in the api)
                   def onKeyDown(key, repeat, flags, view)
                		case key
                		 when @upArrow  then  Sketchup.active_model.active_view.zoom 1.01
                		 when @downArrow  then  Sketchup.active_model.active_view.zoom 0.99
                what i'm trying to achieve is a plugin that will use the keyboard to incrementally spin and turn around the model or a selection. (will be out in 2019).
                  jiminy-billy-bob
                  Indeed much nicer way to do it, jim 😉
