    Vray render & PDF output do not match
    renderpluginsextensions
    2 Posts 2 Posters 813 Views 2 Watching
    • N Offline
      neverbeenbetter
      hi guys,
      Having an issue with my sketchup Vray render matching up with my sketchup exported line pdf. I've go a model in isometric view using Ruby console, i export the view to a PDF then render with Vray, yet the two do not match. The Vray render is at a slightly different angle so when overlaying the PDF lines with the render it doesn't look match. Any help on this would be greatly appreciated. Many thanks,
      Jim
      • andybotA Offline
        andybot
        to render in a parallel projection mode, you need to have the vray physical camera disabled. Otherwise, you will have perspective convergence (however slight) in your render.
