    Push pull all 4 edges at once our scale?
    8 Posts 7 Posters 901 Views 7 Watching
    • ipsketchpiI
      ipsketchpi
      sorry. maybe silly question.
      If I have to get 2mm smaller panel...all for eges must become 2mm smaller.. I use push pull to push 2mm for each edge. Is there faster ways...?
      Thickness should remain as it is.
      /IP
      • david_hD
        david_h
        Try the FredoScale Plugin.
        404 Not Found
        (sketchucation.com)
        • S
          slbaumgartner
          Alternatively, click the scale tool "handle" (green box) in the middle of a thickness edge, wiggle the cursor a bit (to activate the scaling) and then type the desired new sizes into the VCB. The diagonally opposite corner handles as shown selected in your figure scale all three directions at once.
          • sdmitchS
            sdmitch
            Joint PushPull
            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=54771%26amp;hilit=joint+pushpull
            http://sdmitch.blogspot.com/
            • Alan FraserA
              Alan Fraser
              Joint Push/Pull would be my choice too. But, to be honest, it's such a simple operation that it's hardly worth the extra effort of using a script. Just P/P the first edge by 2mm then quickly double-click the other 3 to P/P the same amount.
              3D Figures
              • BoxB
                Nobody's mentioned a simple 2mm offset and push it away.
                • david_hD
                  david_h
                  Sketchup can really do that? Well I'll be. . .
                    So a truncaded pyramid ? Without any Plugin! (a task from my part) πŸ˜„
                    a 0.2 guide line on an edge (if you don't want use a pocket calculator for know how you must type the Scale factor! πŸ’š
                    Double Click on the Top face = Selection
                    Then CTRL + Shift = Scale (XY) from Center with toward the guide line 2 mm
                    (Make a big zoom during the process for have the snap message on the guideline! πŸ€“
                    (Sur la ligne in French = On the line πŸ˜‰
