    PNG Transparency with Styles
    6 Posts 2 Posters 416 Views 2 Watching
    • JoelM3DMJ Offline
      JoelM3DM
      I am inserting png images into SU models, with their background transparent. When the model has no display style and default settings, this works fine (bottom image). However, if I use a style, the entire image becomes transparent (top image).
      This a question I've had for a few years, since I began making videos with SU animation. My solution is Forget about styles and just use the plain default thin edges (see TreasureInside.net). But I want to try something new. Does anybody know of an option or workaround?
      Another solution is to cut away the transparent background, disable transparency, and insert irregular shaped images. This works great, but I don't know how to cut out sections of images. Anybody know how?
      || Joel Metzger 3D Modeling
      || story-shorts.net - Animation with SU
        Yeah, if you apply a sketchy line style the PNGs used for the lines will show through (over?) the image you've imported. It's a well-know issue with no solution other than one of several post=processing options.
        FWIW, there's always a style applied in SketchUp.πŸ˜‰
          TIG's Image Trimmer is what I'd use and make the rest of the image non-transparent.
          • JoelM3DMJ Offline
            JoelM3DM
            That's what I was afraid of. Unfortunately, this is for videos - so post-processing requires much more than a still image rendering.
            So that points to my second question: how do you cut the transparent area out of an image? That way I could insert jpgs without need for transparency.
               - Joel
            • JoelM3DMJ Offline
              JoelM3DM
              trimmed.jpgLookee! Lookee! Thank you Dave!
              A new style dawns for Treasure Inside. - Joel
                πŸ‘ πŸ‘
