    How to create 2 fixed-length beams that pivot together?
    5 Posts 3 Posters 476 Views 3 Watching
    • A
      anotherron
      I am trying to create a model that, at its simplest, is two fixed-length beams. One beam is anchored at a point such as the origin, and it can pivot in a plane at the point. The other beam is attached to the end of the first, and it too can pivot in the plane. I want to be able to move the unattached end of the second beam and have the entire assembly move appropriately. I am unsure if Sketchup is the tool to use or if there is a better tool for this type of model. What other tools should I be considering? If this can be done in Sketchup, I would appreciate any insights as to how to do it.
      Example Beams
      • BepB
        Bep
        Maybe http://solvespace.com/download.pl can be of any help to construct this.
        "History is written by the winners"
        • sdmitchS
          sdmitch
          Are we talking about actual fixed length component beams or just simple edges?
          If it is just two edges as depicted in your post, I think I can help you.
          http://sdmitch.blogspot.com/
          • A
            anotherron
            Thanks! I am looking at its documentation and tutorials. It seems to be just what I am looking for, but the proof will come when I actually try to use it. thanks again.
            • A
              anotherron
              Thanks for your response. I am looking at SolveSpace, which may be just the tool I'm looking for.
              If it doesn't work, I will contact you and see if you can hemp me. Thanks again.
