    Dimensions
    3 Posts 2 Posters 331 Views 2 Watching
    • Z
      Zacchia
      I have some skp files dimension for example hight 100 cm. If Import them in another skp file the Dimension is then larger then in the original file. Why? Where can I adjust that? Many thanks for Feedback.
        It sounds as if you're importing a component that was scaled in your first model after creation. You need to update the definition before you use it for other models. Go to the original file, right click on it. Is "Scale definition" available, i.e. black? If so, click that. It'll update the definition to the current dimensions. Then try importing it into your model
        • Z
          Zacchia
          Yep, that was the Point!! Many thanks!
