    Trim multiple objects against one object in one click
    9 Posts 5 Posters 7.1k Views 5 Watching
    • H
      hugof
      Hi, I would really appriceate a development of the boolean trim function so that you first click on cutting object and then can select several objects to trim at the same time and still keep them as separate groups/components after the trim. Absolute best would be if selecting the objects to be trimmed worked in a similar fashon as the ereaser, so you just click and erease the edges you want to trim away. Currently you have to click on one group/component at a time. This results in very much clicking which is very time consuming if you have hundreds of objects to trim in, for instance, a facade.
      Seems like an easy thing to fix / make a plugin for!
      • cottyC
        cotty
        Have a look at "trim and keep" and "VisuHole" plugins.
        my SketchUp gallery
        • gillesG
          gilles
          404 Not Found
          (sketchucation.com)
          • cottyC
            cotty
            @gilles said:
            404 Not Found
            (sketchucation.com)
            This was my favorite for years and I am still using it too, but VisuHole don't need solids which is a great advantage... see this example screencast:
            [screenr:1re11zb8]7CuN[/screenr:1re11zb8]
            my SketchUp gallery
            • gillesG
              gilles
              Missed this one.
              • cottyC
                cotty
                @gilles said:
                Missed this one.
                You know the important rule "Don't miss a Fredo plugin!" ? πŸ˜‰
                my SketchUp gallery
                • cottyC
                  cotty
                  And a quick "trim and keep" (PRO only) example...
                  [screenr:3sq7npmw]dCuN[/screenr:3sq7npmw]
                  my SketchUp gallery
                  • Jean-FrancoJ
                    Jean-Franco
                    and another important rule >>> Don't miss a cotty tutorial πŸ˜„
                    Jean-Franco
                      Yes Visuhole is a task! 😎
