Toggle On/Off Unit Increment Snapping Possible?
Hi again i notice my Comment is not showing up in forum is there a problem
(ive posted like 2 post a day ago in threads and it does not appear)First of all
Im a fan of using keyboard than The buttons toggling
because i find shortcut keys is more fast productive
and im sorry for many questioning if this is answered in other threadQuestion 1 :
is it possible to add shorcut key for toggling on/off of snap unit increment in SketchUp?
because going to Model Info Dialog box just to turn off and On is not productive at allQuestion 2:
im also looking for toggle Cycle between Wire frame and Solid .. all i find in shortcut is Xray
because sometimes i just want to quickly select Edge lines not the face and i find wireframe is much convenient to useQuestion 3:
Is there a Reselect Selection if selection is quickly snap out or mistakenQuestion 4:
im looking for Explode All Group that become nested or piled because i had of habit where i nested them and i explode all the way until it return to non groupQuestion 5: Im looking for this Tool :
In Blender i Loop Cut > Bevel it and it becomes this
In SU typically i just Divide it .. then Redraw the lines and use Knife Tool then create 4 groups of rectangle and place it center line you cut then retrace it again ( knife tool )
but i like quick like the image above cause sometimes when model becomes complicated it will be time consuming
Thank for Reading , time and answering
@hirokamatsuiko2015 said:
Question 1 :
because going to Model Info Dialog box just to turn off and On is not productive at allI don't know the answer to this one but I guess not natively... maybe a plugin.
Question 2:
because sometimes i just want to quickly select Edge lines not the face and i find wireframe is much convenient to useIt's not possible to assign a toggle for that. It is possible to have a shortcut like "W" for wireframe and "SHIFT+W" for other face style. You can define shortcuts in Window > Preferences or if you're on a MAC Sketchup > Preferences
There is a toogle that might be useful to use to that purpose wich is "K" for backedges on/off. It's what I use as it avoids faces most of the time and you can reference back stuff on the fly.
Question 3:
Is there a Reselect Selection if selection is quickly snap out or mistakenThere's a plugin that does this though I never used it. I don't know if it's 2013/2015 compatible...
Question 4:
im looking for Explode All Group that become nested or piled because i had of habit where i nested them and i explode all the way until it return to non groupThere are also plugins for that around here. If you want to do that without plugins, best way would be through outliner.
Question 1 :
Question 2:
Question 3:
Question 4:
About Q1 :
i hope that theres a way to toggle in and off because its pretty handy combining with
( Toggle units Plugin )About Q2 :
ah yes i know that but im saving up keys anyway and i want to toggle it by using 1 key only in most of 3d Program i use X for toggling Cycling i just had muscle memory where
i really cant assign 2 keys for solid and wireframe i tried it but icant adapt itAbout Q3 :
Still looking for this ... Reselect is a must i just dont know why Undo Command doesnt detect the previous selectionQ4 ( Is Solve )
im using Explode To Groups By TIG ( thank you ) -
@jql said:
now my selection is complete inverse selection and Cycle selection ( Undo Selection ) ..
Plugin Use : vertex tool and Selection memoryi just wonder why sketch up doesn't have these tool available as a default
thank you again
1: ToggleUnits http://sketchucation.com/forums/viewtopic.php?p=81391#p81391
you only need to assign a shortcut to the the precision +- pair...
Register LoginAdvertisement
