    Im looking For this Plugin .. ( long list )
    5 Posts 3 Posters 554 Views 3 Watching
    • H Offline
      HirokaMatsuiko2015
      Hi would like to ask if this plugin exist its been awhile i havnt use sketchup
      1. Subdivide = Form Grids to selected face and can Input Number ( doesnt Smooth Out )
      2. Loop Cut = Able To Cut and enter desired number
      3. Duplicate Command = Copy + paste in one command ( Able to reconfig with hotkey )
      4. Zoom In Zoom Out = with ratio ( Able to reconfig with hotkey )
      5. Toggle Select Face or Edge ( i already have vertex tools but im missing face and edge )
      6. toggle between Xray and solid ( for example if i hit X it will cycle )
      7. recalculate normals or fix the face direction
      8. Lasso and Polygonal Select
      Thank you in advance
      • cottyC Offline
        cotty
        1. maybe FaceSplit?
        2. Basic functions are in the QuadFaceTools
        3. You can assign a shortcut to "paste in place", so it is possible with two hotkeys
        4. Maybe SelectionsTools?
        5. you can assign a shortcut to "x-ray" and toggle with it.
        6. There are several, one new (for making solid) is Solid Inspector 2
        my SketchUp gallery
        • H Offline
          HirokaMatsuiko2015
          1. maybe FaceSplit?
          Hello
          1. tried face split doesnt work SU2014
            .. i find another solution plugin is called ( Projections )
          2 ) i tried this plugin but it cant input how many desired loop cut
          for now my only solution is im combining Projections + knife tool
          3 ) Place in place is blank out ..
          what i mean is that if i select an object or face line vertices it will automatically
          copy + paste then activate move with single key
          5 ) Semi-Solve for edge select its called ( Hover Select ) but im still searching for face select
          6 ) Solve*
          7 ) Solve*
          thank you again
            driven
            1: maybe split up? http://sketchucation.com/pluginstore?pln=SplitUp
            3? so you want move to default to move copy?
            • H Offline
              HirokaMatsuiko2015
              1 : nope thats not the effect im looking for i think i might stick with ( Projections + Knife Tool )
              i can form grid to this tool or turn the tool for making equal space loop cut
              2: it was similar function to blender where you just select an object and instantly duplicate it by hitting a 1 command then it activate the move tool where you want to place it
              in Sketch up i need to hit CTRL + C then CTRL + V and and repeat CTRL +V for duplicate
              2 hotkeys were performed
